Advanced Search of PWP Forums
The forum's FAQ mentions a link to advanced search - I can't find it. Is there a way of using some sort of boolean search of the forum?
Re: Advance Search of PWP Forums
The only search of the current forum that I am aware of is the search field displayed above the topics. There is also a search of our older message board accessed via the Search Archive choice to the left of the Login/Logout option.
Re: Advanced Search of PWP Forums
phpBP FAQ mentions an 'Advanced Search' - perhaps there is a switch in their Admin panel to show it?
http://www.dl-c.com/board/faq.php#f70
The only reason I'm asking is that often searches return no results because the search terms are, I think, treated as joined by OR - and there are too many hits. For instance, I remembered vaguely a discussion on Color Balance (and whether its Auto settings are trained on each image in turn or the first one in a sequence) - I tried to look for 'color' and 'balance', but couldn't get to it. Then I figured I probably commented on it, so I went through my own posts and eventually found it. I was hoping for something like AND or NOT but I couldn't figure out how to do it.
Kiril,
On the php site, in the support forum there is a "Advanced Search" function:
Offers a bunch of search functuions:
https://www.phpbb.com/community/search.php
An option is to use Google Advanced Search. In addition to boolean operators for search terms, it allows you to restrict the search to a particular site or domain. I just tried it for color balance and retrieved many forum posts.
mjdl
Post by mjdl »
For what it's worth, here's what I do to search the Picture Window support board using Google and the Firefox browser.
1) I use Firefox's "Search Bar" function, the text search field that is part of the default top bar at the top of the Firefox window, and I also use "Add to Search Bar" and "Organize Search Engines" Firefox add-ons to add and edit search engines to the drop-down list of that text search field.
2) All such addition search engines are stored as individual XML format files (XML files are the cigarette butts of the Internet, but I digress...) in the "searchplugins" folder in your Firefox profile folder. Your current profile folder may be found by displaying the URL about:support. The searchplugins folder is scanned each time Firefox starts and new searchplugin files are recognized then and added to the drop-down list.
3) To search Google for forum postings, append the search terms to the search operator terms
Code: Select all
site:dl-c.com inurl:board/viewtopic.php
4) With a little editing, that leads to the following searchplugin contents:
Code: Select all
<SearchPlugin xmlns="http://www.mozilla.org/2006/browser/search/" xmlns:os="http://a9.com/-/spec/opensearch/1.1/">
<os:ShortName>DL-C.COM board - Google Search</os:ShortName>
<os:Description>DL-C.COM board - Google Search</os:Description>
<os:InputEncoding>UTF-8</os:InputEncoding>
<os:Image width="16" height="16">data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAABHElEQVQ4jZ2TPUvDUBSGD/6X/gbBzbH9B67+Ah0EKYE2lLpUMtghiBRL2g5dLIpCEAp+TKIOFRFcBPsVEEobuxiIfRyCxo9Ebjqc4T33nuec+3KuZMVP54VhXiBhDLPip2XO4i+IxB1aG2BtQuca3mdwUoGdxb/3IgEtE2paqB86cH4c3SgSMHVhdyXUe6vw5iUAuBOwa6E2UtB9SgCoroHnQXkJCgL2PmzHeBVrYkmgug4zfj5HGfAZry7c3wSTKAPKy3BogqVBswTjEQx6UFQBNHS4vQT9W64o0H0Gu64AcPrBAkUtVvtAAXBhB922fuWv2mAsKAAKAkcmvAzg8Q7OWnBaB+MfE+f+TDnBEU38TE5wkhbrQl8TP/MBHZunUIwQaBgAAAAASUVORK5CYII=</os:Image>
<UpdateInterval>1</UpdateInterval>
<SearchForm>https://www.google.ca/</SearchForm>
<os:Url type="text/html" method="GET" template="https://www.google.ca/search">
  <os:Param name="q" value="site%3Adl-c.com+inurl%3Aboard%2Fviewtopic.php+{searchTerms}"/>
</os:Url>
</SearchPlugin>
5) Copy and save that text into a file dl-c-board-search.xml in the searchplugins profile folder, and restart your Firefox browser. You should now have "DL-C.COM board - Google Search" as one of the choices in the search bar dropdown list.
6) I hope this searchplugin works for Firefox users; I did try it in a new Firefox profile and it works for me.
minolta
What is the make/model of your primary camera?: Sony Alpha a7R IIIA
Post by minolta »
mjdl wrote:For what it's worth, here's what I do to search the Picture Window support board using Google and the Firefox browser.
Thank you for this great tip! Your instructions were clear enough for me to follow. Not only does it work like a charm, I learned some new things about Firefox, too!
minolta
Carl R. Evans
Thank you 'mjdl'... ...like 'minolta' your instructions/script work for me with Firefox 24...
mjdl
Post by mjdl »
Here are updated Firefox search plugin files for the old archived DL-C.COM board and for the current DL-C.COM board which have a proper DL-C.COM embedded icon, rather than a generic Google search icon.
Save this as e.g. dl-c-com-new-board.xml:
Code: Select all
<os:ShortName>DL-C.COM new board - Google</os:ShortName>
<os:Description>DL-C.COM new board - Google</os:Description>
<os:Image width="16" height="16">data:image/png;base64,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</os:Image>
<SearchForm>http://www.dl-c.com</SearchForm>
<os:Url type="text/html" method="GET" template="https://google.ca/search">
  <os:Param name="q" value="{searchTerms}+site:dl-c.com+inurl:viewtopic"/>
</os:Url>
</SearchPlugin>
And save this as e.g. dl-c-com-old-board.xml:
Code: Select all
<os:ShortName>DL-C.COM old board - Google</os:ShortName>
<os:Description>DL-C.COM old board - Google</os:Description>
<os:Image width="16" height="16">data:image/png;base64,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</os:Image>
  <os:Param name="q" value="site%3Adl-c.com+inurl%3Adiscus%2Fmessages+{searchTerms}"/>
</os:Url>
</SearchPlugin>
