Profile problem
afx
Profile problem
Post by afx »
Hi,
I am trying to use a profile from Museo for their Artist Cards on an Epson R3000.
http://www.museofineart.com/files/2613/ ... NR3000.zip
The softproof matches the print, but it is all monochrome blue which is not intended.
Other Museo papers work just fine. Any ideas what is wrong?
cheers
afx
Signature for rent.
alain
Re: Profile problem
Post by alain »
Hi
Maybe it's a icc4 profile instead of a icc2 profile.
Alain
Re: Profile problem
If the softproof matches the print, then it sounds like there may be something wrong with the profile. I notice the profile is more than 3MB which is quite large. Are the other similar profiles you have of comparable size?
afx
Re: Profile problem
Post by afx »
Yes, it is an ICC4 profile as far as I can tell and it is also the only monster of this size....
cheers
afx
Signature for rent.
alain
Re: Profile problem
Post by alain »
try to get a icc2 profile. As far as I know and have seen pwp doesn't support icc4 profiles. (Like a lot of other programs.)
