PWP 8.0.540 crashes upon attempting to load the Distort transformation in the attached workspace.
I got a new computer over the summer, and I went back to the old one (running 8.0.513) and PWP crashes on that as well.
PWP 8 Crash While Loading Workspace with Distort Transformation
jfoster
- ice - Crash Copy.zip
- (4.68 KiB) Downloaded 170 times
Re: PWP 8 Crash While Loading Workspace with Distort Transformation
It looks like Distort was using a lot of stack space which could cause an overflow. Fixed for next release.
jfoster
The original file is a 4480 x 6720 48bit tif that doesn't compress down to typical email attachment limits. I created a proxy (blank white) 4480 x 6720 48bit tif and replaced the original with it. It seems to create the same crash. Attached is a zip of the proxy. Is that doesn't work for you, I'll post the original on my website for download. Let me know how you make out.
Oops. I didn't see your edit b4 I posted this.
- _O1D8913_DxO.zip
- (186.51 KiB) Downloaded 170 times
Thanks, I was eventually able to reproduce the problem without the file -- it worked at first because the debug version I normally test with has more stack space allocated to it.
