New histogram option in the Levels and Color
It looks like the adjustments in Dynamic Range Slider is independent of the adjustments using Histogram option: it's either one or the other. I haven't tested it yet, but I wonder how the auto dynamic range settings for the Slider (in options) are applied when the Histogram option is on. Also in 'batch - would the histogram stay constant for subsequent images or would it be adaptive, as the Dynamic Range Slider can be made to be?
Re: New histogram option in the Levels and Color
If you use the curve instead of the sliders, there is no auto-range option since the same curve is applied to all images in a batch workflow. If you want some kind of autorange in batch, you need to use an Autorange transformation before Levels and Color.
