problem : PWP crash while using the Frame transformation
Debugging Session state and workspace recovery attached
2024-12-01 Frame Picture Window Pro.zip
(3.25 KiB) Downloaded 244 times
Re: problem : PWP crash while using the Frame transformation
The attached workspace file does not include a Frame transformation. Generally you are better off saving one of the Autosaved workspaces if you want to recreate a problem. The Session state file is also mostly unnecessary.
jsachs wrote: December 1st, 2024, 9:14 pm Generally you are better off saving one of the Autosaved workspaces if you want to recreate a problem.
Is there a folder with several auto saved workspaces ?
My Documents\Picture Window Pro\Workspace Scripts
I looked at the code and Crash Recovery.workspace is simply a copy of Autosave.workspace. Autosave workspaces however are only written out when you click OK in a transformation or perform certain other operations such as closing a transformation so there is no guarantee they represent the exact state of the workspace at the time of the crash.
