problem : PWP crash while using the Frame transformation
Debugging Session state and workspace recovery attached
Re: problem : PWP crash while using the Frame transformation
The attached workspace file does not include a Frame transformation. Generally you are better off saving one of the Autosaved workspaces if you want to recreate a problem. The Session state file is also mostly unnecessary.
My Documents\Picture Window Pro\Workspace Scripts
I looked at the code and Crash Recovery.workspace is simply a copy of Autosave.workspace. Autosave workspaces however are only written out when you click OK in a transformation or perform certain other operations such as closing a transformation so there is no guarantee they represent the exact state of the workspace at the time of the crash.
