Chrome and phpBB
Chrome and phpBB
I'm having trouble with the PWP phpBB board in Chrome. The text edit box is not displayed in Chrome (updated) no matter what I do. I resorted to write this message in Edge, which displays is. I haven't had this problem with Chrome until recently - I'm not sure how to diagnose or solve it.
- Chrome
- 2021-01-26_090656.jpg (27.11 KiB) Viewed 5133 times
- Edge
- 2021-01-26_090731.jpg (36.98 KiB) Viewed 5133 times
Re: Chrome and phpBB
I use Chrome all the time and have never seen this problem. You might try updating to the latest Chrome -- click the 3 dots icon in the upper right corner, select Help/About Google Chrome. Also check that you are running the 64-bit version.
I keep fighting with this Chrome curse, and it seems that if I change the account which has no extensions installed, everything works as it did before. So my conclusion is that its one of the extensions that interferes with the phpBB. How do I find which one - turning them on and off one by one? Is there a way to diagnose it in some other way? Thanks!
Turning off extensions an Chrome applications didn't quite work either. An interesting part is that the same thing happen on two computers, on each of the two accounts that I'm using, but only when I log into the accounts (and thereby synchronize the extensions, or so I think).
For the record, I think I finally found it: it was Chrome browser extension "GPS Coordinates for Google Maps" that was messing things up...
