Change Profile
Change Profile
It may be good to add "Change Profile" to the list of possibilities displayed after clicking on "Transformation" and highlighting "Color".
Re: Change Profile
Currently it is listed under Gray because, unlike PWP 7, PWP 8 can set profiles for black and white as well as color images. I could potentially list it in both menus although that might be equally confusing.
Re: Change Profile
Since you would get to the same transformation from either the gray or color routes, listing in multiple locations to me seems more helpful than confusing.
Re: Change Profile
By that reasoning, every transformation under Gray would also be listed under Color.
Re: Change Profile
That is a problem with most of the "Gray-"Transformations. They work with color and b/w images.
The "Color-"Transformations just work with color images.
So the word "gray" might be misleading. But I don't have an idea for a better one.
migrated to Windows 10 in Nov. 2019
CUDA not available
CUDA not available
Re: Change Profile
For the next release, I moved Change Profile out of Gray to the next higher level of the menu.
Re: Change Profile
With logic appreciated, I would like to point out that the Transformation menu is getting pretty long - but that's all good as Quick Pick is a life-saver!
