Update Available - Version 8.0.75
An update is available to Version 8.0.75 (29-Mar-2020)
File Open: fixed problem causing black output image in certain obscure cases.
Precise Gaussian Blur: removed the change from the previous version, and instead added a checkbox to use the Amount mask as the Blur mask.
Amount Controls: fixed problem with a list of mask images being displayed in the Amount menu when the Amount control is not reset.
jfoster
Re: Update Available - Version 8.0.75
Post by jfoster »
First run through of the single-mask PGB worked fine. Didn't poke around with it much, but will post issues if I find them. Thx.
jfoster
Post by jfoster »
Noticed that PGB Amount mask pull-down menu includes wrong sized masks.
In this example, only "23 - Resize" should be in the selection list (at least that's the way I remember it working previously).
OK, I see the problem -- I introduced it recently when trying to fix a problem in Composite with masks not showing up in the menu. I put the code back the way it was and am working on a different fix for the Composite bug.
jfoster
Post by jfoster »
Emailed you the workspace file.
OK, I think I have the Amount menu working again with the Composite bug fixed as well. Will do some more testing tomorrow and upload a new version.
