High Pass and its low pass counter part
Is there an easy way of obtaining the discarded low-pass portion of an image in the High-Pass transformation. I was thinking of blurring the image with the same radius, but I'm not sure the blurring methods/radii are corresponding somehow. If they are not, would it be difficult to have an option in High Pass to output the low pass portion, if requested?
I was hoping to experiment with various blending gambits...
Re: High Pass and its low pass counter part
You can make your own high and low pass images easily:
Low pass is just a straight Gaussian blur of the same radius with no halo reduction or threshold.
High pass is the offset difference between the original and the blurred version.
Cheers!
