Crop does not accept cm and mm values
Crop Transformation accepts only inches. When the units are set to cm or mm, Physical Width and Height values are multiplied and overwritten.
Re: Crop does not accept cm and mm values
I found a problem where cm and mm were reversed. Is there something else?
I am very very sorry, I ment Resize not Crop.
Crop was what I was playing with before.
Fixed in next release.
Don't feel bad -- if you had not made the mistake, I would not have found the bug in crop.
Well, I should feel a bit bad, because I have not discovered the bug in the Crop. :)
Anyway I have an additional observation regarding the Resize, which I am not sure is part of the original problem I tried to describe. It is about leg in the screen refresh.
Here is the whole description.
Preferences: Units: cm
image info:
2868 x 4320 @914.4 dpcm
20.235 x 30.48 cm
Displayed info in Resize dialog before any change:
Pixel Width/Resample
Width 2868
Resolution 141.732 dpcm
then:
change set to Physical Width
change Physical Width to 15 cm -> PWP automatically recalculates it to 96.7749 cm, and resolution to 21.969 dpcm
change the resolution to dpi and to 288 -> the Width recalculates to 624.3546 and the output turnes into an error.
but:
change first the dpcm to dpi -> the resolution recalculates to 360
change 360 to 288 -> the Width recalculates to 130.5542
Then when I then try to move the dialog, there is an unpleasant lag in the screen refresh .
I fixed several problems in Resize. As near as I can tell, your example should now work, but I am not entirely confident that other problems do not remain. Will do some more testing and post and update tomorrow.
