1. On my new Windows 7 (64) with a 2560 x 1440 monitor, with the operating system font size set at 125% (medium), the content of the raw conversion window runs into the right edge of the window, thus obscuring the rightmost 5% of the information. The problem is shown on the attached image.
2. On my system as described above, in PWP (only PWP, other programs are fine) the icons and font sizes are uncomfortably small. Is there any way within PWP to enlarge them? If I try shifting the system to enlarge fonts and icons, the fonts and icons in all the other programs become too large.
3. The bright red and yellow of the PWP 7 icon are awfully bright, not in keeping with the subdued and comfortable colors of PWP itself.
Windows contents overrun window space
Robert Schleif
- window problem.jpg (68.57 KiB) Viewed 3776 times
Re: Windows contents overrun window space
Robert,
First, please make sure you are running the latest version -- PWP 7.0.11.
You can control font size in File/Preferences. You can also choose one of three widths for the Raw Dialog right panel in File/Raw Settings. It may be that for your monitor/font combination, you need to widen the panel. If none of the settings work in your case, please send me a screen shot at support@dl-c.com.
Robert Schleif
Thank you for your prompt reply.
Yes, I am running version 7.0.11.
Adjusting font size in preferences takes care of the problem. As long as the font size scale factor is 100% or less, the window contents fit within the window, but if the scale factor is larger than this, a portion of the right edge of the window contents is lost.
