Depending on the font scale factor setting in Preferences the Histogram Tool shows irregularities in the grid. Upper image: scale factor from about 97% to 113%.
As the font gets larger, over 113%, and Histogram Tool box gets wider, the histogram inevitably stretches out with white gaps, however this can be misleading because the tool box is at its default width and cannot be made narrower. It creates an impression that the histogram is sparse even though the image has enough information in it. The lower image.
PWP 70.6. 64, Win 7 64.
Monitor Samsung SyncMaster XL20, resolution 1600 x 1200 (Recommended)
David
Font size and Histogram Tool
- Histogram2.png (5.48 KiB) Viewed 7799 times
Re: Font size and Histogram Tool
I have noted this too, running at fontsize 116% at a screen res of 1920 x 1080.
To my opinion it would be vey useful if the vertical "bars" of the histogram could be made wider when the histogram window is made bigger in width, so that there are gaps in the histogram just where actual gaps are, and not just because the "bars" are thin.
Another thing i would like to suggest for Histogram is the vertical scale. It is divided in 10 sections, but when the histogram is expanded the vertical axis is not linear anymore, could the sections follow this unlinearity ? Like on a logarithmic paper? So that at the bottom the distance is wider then on the top, accordingly to the expansion ?
It would be easier to read a expanded histogram, to my opinion.
One more comment, more cosmetic than functional. There seem to be a change in the font type in PWP 7.0.6, which is a little bit pity because the previous one made better use of its "allocated" space. Perhaps it was necessary because of the proportionality of the font?
The first image is from PWP 7.0.5. The upper and middle parts of the second image are from the PWP 7.0.6 Color Picker at font scales 113% and 115%. The bottom part is from the PWP 6.0.10 Color Picker.
David
David
- PWP 7.0.5
- Font PWP 705.jpg (11.78 KiB) Viewed 7717 times
- PWP 7.0.6, PWP 7.0.6, PWP 6.0.10,
- Font size.png (5.47 KiB) Viewed 7764 times
These problems have all been fixed in the next release.
