Test pattern checkerboard does not accept cell size 1
The checkerboard does not accept cell size 1 : when 1 is entered, it uses two instead.
2021-02-26 PWP8 checkerboard does not accept cell size 1.png (93.82 KiB) Viewed 3770 times
Re: Test pattern checkerboard does not accept cell size 1
The minimum checkerboard cell size is 2. Picture Window does not handle 1x1 pixel images for various reasons, so setting the minimum cell size to 2 prevents this from happening, no matter what the number of rows and columns is set to.
The Resolution Chart test pattern has a section of 1x1 checkerboard which you could crop out if you really need it.
Hi Jonathan
Couldn't PWP8 checkerboard accept a cell size of 1, while disallowing a total image size of 1x1
It could. Fixed for next release.
Thany you for the fix !
