No Histogram Expansion in AS
I'm not sure if I've reported this cosmetic issue: in AS/Opt., there is initially no checkmark at (No, or any other) Histogram Expansion.
Re: No Histogram Expansion in AS
I don't see this here, but it is likely caused by an obsolete or corrupted version of default.as (the saved default settings for AS) on your system. If you re-save your settings with histogram expansion set to a legal value the problem should go away.
That fixed it. Thank you.
