New Picture Window Update
The Picture Window Pro 7.0.11 update is now available.
The update fixes bugs reported since the original PWP 7 release. It also adds several small features:
  • Change Color Profile now allows assigning a new profile to the input image in addition to changing the profile of the output image.
    Text and Album now support wide characters, allowing you to mix alphabets in the same text stream. There is now also a button to display the Windows character map for entering symbols and other characters not represented on the keyboard.
    The workflow window now accepts drag and drop of files from mixed folder. This allows you to drag files from a Windows search, for example.
    The 32 bit version is now built so that it no longer requires the SSE2 instruction set. (SSE2 was introduced about 10 years ago as a Pentium enhancement.) This makes PWP compatible with older systems that do not implement these instructions.
For full details of the changes see http://www.dl-c.com/update70.html
The new software can be downloaded here: http://dl-c.com/content/view/23/54/
