Run Workflow on Images: can't close dialog
Right-click dropping image on an open window, opens a Run Workflow on Images dialog. There is an option of opening an image or running a workflow on it, which work fine. But the close [x] button in the upper right hand corner doesn't seem to close the dialog and do nothing. Is that intended?
Re: Run Workflow on Images: can't close dialog
Currently there is no cancel at this point in the operation -- you must choose one option or the other.
For the next release closing the dialog will operate a cancel option.
