PWP 7.0.7-32 -- Workflow - AdvSharpn widget
Moderators: ksinkel, jsachs
For a PWP7.0.7 previously saved, then loaded Workflow containing an AdvancedSharpen widget the Sharpen tab's Sharpen Radius is not 'remembered'.
The Noise Reduction and Speck Removal tabs have 'default' settings with the transform Amount setting of 66.7% which is expected...
The 'saved' Sharpen tab...
saved AdvShrpn widget.jpg (44.73 KiB) Viewed 6060 times
The 'loaded' Sharpen tab...
loaded AdvShrpn widget.jpg (44.68 KiB) Viewed 6067 times
3 GB DDR2 dual channel RAM
2 MB ReadyBoost Cache
Re: PWP 7.0.7-32 -- Workflow - AdvSharpn widget
Addendum 1...
For a PWP7.0.7 previously saved, then loaded Workflow containing an AdvancedSharpen widget the Noise Reduction tab's Blur Radius is also not 'remembered'.
Other settings including sliders for the Noise Reduction, Speck Removal, and Sharpen tabs are 'remembered'.
Just the radius settings for Noise Reduction Blur Radius and Sharpen Radius if different then 'default' do not seem to be 'saved' when the Workflow is saved and closed; then re-opened for another set of images.
Den,
Thank you for the report. This will be fixed in the next release.
