Inactive Undo button in Mask dialog
Moderators: ksinkel, jsachs
Charles2
Post by Charles2 »
All of a sudden the Mask Undo button is inactive for default freehand masking. Other Mask commands like oval, brightness, and flood fill work. Ran the beta several times, opened several different images - Undo button grayed out and inactive. If I proceed to feather or blur, after doing that the Undo button returns to active. Ran PWP 6.0.10, no problem.
In the past while in a Mask operation I have had crashes, this beta and previous versions. I have not been able to find an image and set of mask commands that always crash.
Re: Inactive Undo button in Mask dialog
Not seeing any of that here. Can you be a little more specific about which version you are using and what kinds of files?
Charles2
Post by Charles2 »
PWP beta 7.0.5
my computer as described in Feb. 18 email to you
TIF files
If there are .dll or auxiliary PWP files you would like sent back to you, let me know.
Charles, the most recent version is 7.0.6.
Maybe you try with this version ?
Normally the Undo button should be enabled as soon as you click on the image in Freehand mode. If you are almost out of memory, Undo gets disabled but you should get a message first.
Are you using the 32-bit or 64-bit version of PWP? Are the files large? What are your virtual memory settings?
Charles, something similar has already been fixed in version 7.0.6.
http://www.dl-c.com/board/viewtopic.php?f=10&t=732
David
Charles2
Appears fixed in 7.0.6
Post by Charles2 »
I gathered the data requested, then saw David's post and upgraded from beta 7.0.5 to 7.0.6. That fixed it. My apologies for not checking whether I had the most recent beta.
