PWP and 32 bit floating point numbers
Bernard
Post by Bernard »
Merging several bracketed photos into a HDR image produces 32 bit floating point numbers representing pixel values, for example in a '.EXR' file.
It would be interesting to continue editing of these images in 32 bit mode, before converting them to LDR 8 or 16 bits.
Are there any plans to adapt some PWP transforms to 32 bit floating point mode ?
Bernard
Re: PWP and 32 bit floating point numbers
In my opinion, 32-bit floating point is extreme overkill for working with photographic images. 16 bits per channel is more than enough to represent any scene - especially when you take into account that no monitor or printer can display more than 8 bits per channel.
afx
Post by afx »
jsachs wrote:... no monitor or printer can display more than 8 bits per channel.
Hmm,
check out high end Eizos, NECs and the latest offerings from Dell and LG.
Attached to a Windows system via DisplayPort with the right cards (FirePro for example), they have a 10 bit data path.
cheers
afx
Signature for rent.
10 is still a lot less than 16 -- mostly the extra bits are useful for loading lookup tables since the eye can barely distinguish 200 different gray levels under ideal conditions.
Bernard
Post by Bernard »
Jonathan,
I don't disagree with you, however bracketing and HDR is sometimes the only way to represent a scene with extreme contrast.
The result may be a '.EXR' file in 32 bit floating point, therefore my question ...
Bernard
Understood.
We might consider for the future versions reading EXR files and converting them to 16-bit.
Most HDR programs can output 16-bit files as well which can represent an extra 8 stops of dynamic range over 8-bit files.
Bernard
Post by Bernard »
That would be nice !
Bernard
