Chromatic Aberration transform request
Jonathan...
You have been very responsive for PWP7 beta... ...my thanks!
Please consider upgrading the lateral Chromatic Aberration transform to also have:
(1) OPTions: "save"; "load"; and "Reset" to 0.0000%/0.0000%
(2) A "blink" Preview feature similar to the "shift-left mouse click" on the Amount mask button for other transforms between a R/B shift setting and 0.0000%/0.0000%... ???
I find myself using this transform more and more to produce fine quality images but my eyes do not always easily detect nuances in adjustments... ...I can and sometimes do create comparisons using the Blink transform but if the comparisons could be done directly in the transform... ...and hopefully these changes could be also made for its workflow widget as I will often use it as a 'breakpoint'.
Initial 'lateral' chromatic aberration correction early in a post-raw conversion editing workflow before cropping; tone/color contrast changes; and sharpening seems to significantly reduce visible purple/yellow-green fringing in the final image version.
Re: Chromatic Aberration transform request
I was able to get this into the next beta release
Thank you... ...this is greatly appreciated. ...den...
