Reset all in Mat & Frame
Moderators: ksinkel, jsachs
Reset all command in Mat & Frame transformation does not reset the the Color/Image pickers on the Inner and Outer tab and Color picker on the Wall tabs, and causes that an image loaded into Color/Image pickers, cannot be closed after the transformation is closed - there is the message "Window used by Mat - Cannot close.
The image cannot be closed neither if it had been replaced by a solid color before the transformation was closed.
All this seem to be linked to the Reset all command. If not used, there is no problem with closing loaded images after the transformation was closed.
PWP32 on Win XP32
Re: Reset all in Mat & Frame
This should be fixed in the next beta release.
PWP 7.0.6 - 64
The Reset All still does not reset the color rectangles of the Inner, Outer and Wall tabs to their defaults (75.3,75.3,75.3),(96.1,96.1,96.1),(94.1,94.1,94.1) so that they correspond to the preview.
David
