Workflow and Breakpoint on RAW widget
Is there a way of 'breakpointing' the RAW widget? I would find it useful as I'm trying to use workflow with breakpoints to semi-automate the processing of images, but still making individual adjustments to some widgets - RAW would be one of which I would like to adjust individually. Cheers!
Re: Workflow and Breakpoint on RAW widget
Not currently, but that's a good suggestion for the future.
One work around currently would be to go through the raw images separately and establish a workflow file for each one. When raw is later opened in a workflow with other operations, the raw workflow file is used to open the image (if one exists) so your individual raw settings would be honored.
