Canceling the Workflow with Breakpoints - or fast forwarding
Is there a way to either cancel the workflow with breakpoints or ignore the breakpoints and process the rest of images according to the last widget settings? I tried Cancel button but it didn't seem to work for me. Also, when I hit Cancel button in the widget with breakpoints, the last input image seem to freeze in the 'before' window, but the subsequent images seem queue up to be processed and the 'after' view show them normally.
Re: Canceling the Workflow with Breakpoints - or fast forwarding
When the workflow pauses during a breakpoint, you can unset one or more breakpoints. They will then not pause the wokflow for the remaining images.
Thank you Kiril! Canceling the breakpoints allows to 'fast-forward' the workflow.
In the workflow with or without breakpoints, I don't seem to be able to Cancel it while in progress by hitting the Cancel button in the Workflow Execution Progress window, when Multitasking is turned off. In the workflow with breakpoints and the multitasking on, the Cancel seems to work.
