Correcting portraits taken with too wide lenses
It's well known that using too wide lenses for portraits probably won't make you many friends. This example shows how this could be corrected in PWP post-processing. I used Displace transformation on the original, in circular mode, negative magnification and the face covered with diffused mask.
Portrait Example on Diet.jpg (49.44 KiB) Viewed 8724 times
Portrait Example Original.jpg (49.67 KiB) Viewed 8729 times
MikeG
Re: Correcting portraits taken with too wide lenses
Post by MikeG »
Neat.
Thank you for introducing me to a another technique.
Mike.
A discussion on how to change the centre of circular 'shrinking' by adding borders to the image, and then cropping it back again.
http://www.dl-c.com/board/viewtopic.php?f=4&t=584
