A few minor issues
A few minor issues
A couple of mostly cosmetic issues before I lose the notes:
1) Channel Registration: Reset resets the offset values, but doesn't update the preview (Auto or otherwise).
2) Button: Reset resets all colours, but doesn't update the 5 colour swatches/squares in the dialog window.
3) Mask: remembers the window size of the last tool, but starts with Freehand tool as a default, often resulting in larger empty window than needed. e.g. use Brightness Curve tool in Mask, close the mask control window, reopen again.
4) Help: Drop Shadows is a sub-item of the Calendar section.
Re: A few minor issues
Thank you for the report. I will take at look at the issues you raise.
Joel
What is the make/model of your primary camera?: canon
Post by Joel »
5 ) RAW dialogue box (first opening raw file) : Default sharpen radius value is.. 6.
Config : XP SP3 32 bit
There are two ways to change the RAW sharpen radius default that I know of:
1) File/RAW Settings
2) RAW dialog/Save as Camera Default
The first one is a generic default. The second one will take precedence if saved and the image EXIF matches the camera again. Either of these defaults will kick in only if a) there is no sidecar file already, b) you haven't changed the RAW sharpen radius manually for previous images in the same PWP session.
Cheers!
Joel
Post by Joel »
Thx ;)
