Problem with tiff to jpeg conversion in workflow
HanSch
Post by HanSch »
Hi,
I tried to convert a set of tiff images to jpeg images in a PWP 6.0 workflow. The tiff-files had been generated in PWP 6.0. The conversion is the only widget I use in this workflow: Output - Rename/File save. The workflow fails: no conversion, "xx images had errors". I tried the same in a PWP 5 workflow, with the same files; no problems.
Then I tried again in PWP 6, but I added a widget (arbitrary) to change color saturation, then conversion from tif to jpg. This time the workflow does it's job fine.
What's happening?
Re: Problem with tiff to jpeg conversion in workflow
This is a known problem that is addressed in the next release. The present workaround is to turn off multitasking. There is an option for this under the File button in the workflow window.
