Kiril/Jonathan,
I am running 64-bit Win7 with a multiple core cpu. I am using a workflow created under 5.0.1.9. The workflow simply resizes, sharpens, and saves jpegs in a directory.
When running the workflow under 6.0beta, I notice (1) images are processed in parallel (nice), and (2) some of the images are marked with a red "X" when processed, instead of the checkmark. After all images are processed, the summary dialog gives me a count of images processed correctly, and counts the "x"-ed images as having generated errors. Right-clicking on the thumbnail with the red "x"and listing the error message says -- "Unknown error reported by LeadTools". As best as I can tell, the workflow does successfully generate the new resized images properly.
Bob W
Workflow Error
Bob Walker
- What is the make/model of your primary camera?: Canon R5 m2
Re: Workflow Error
Bob,
Can you send me your original workflow.
Thanbs,
Thanbs,
Re: Workflow Error
I have confirmed the Leadtools error "Unknown error reported by Leadtools" when saving jpg files. The error is a result of multitasking the Leadtools library. It will take me sometime to research this properly.
For the time being, the workaround for anyone encountering this error when saving jpgs in a workflow is to turn off multitasking.
To turn off multitasking in the workflow:
1. Click the File button.
2. Select "Do Not Multitask".
This setting can be saved a part of the workflow by simply saving the workflow.
Please note this is not an issue when files are saved as Tiffs.
