Picture Window Pro 6.0 beta version is now available. Many new features have been added. Here are some highlights:
64 bit support. for editing very large images and accessing all available memory.
Raw improvements with better color and tonality as wel as better performance. Extracting full resolution jpegs has been added.
Workflow Improvements including breakpoints, new widgets, beter performance and "drag and drop" editing.
New and Improved Transformations including a new Noise Reduction transformation.
Album now supports text and autosaves its images.
I want to particulary highlight Breakpoint and Drag and Drop editing. These can be game-changers for editing large sets of images.
Breakpoints allow you to pause the workflow at a particualr operation, so you can set the operation manually. For example you might run a complicated workflow against scores of images automating eveything except, say, cropping. By setting a breakpoint there, you can custom crop each image while still taking advantage of automation for everything else.
Drag and drop editing allows you to automatically apply all the editing steps you perfomed pn an image to other images by simply dragging them from the browser and dropping them on the edited image. So you can automate with absolutely no preplanning or extra steps.
New features and download instructions are available here:
http://www.dl-c.com/Temp/pwp60beta/pwp60beta.html
Posting Comment and Bug Reports
Please post these in the new PWP 6 Beta forum. Also before posting a bug report, please search the forum to make sure the bug has not already been posted. Thank you for your help and cooperation.
PWP 6.0 Beta Now Available
