Level and plumb widget causes problem
Rawcoll
What is the make/model of your primary camera?: GH2, G80, (Fuji XT-1)
Post by Rawcoll »
Hi
I have an existing workflow comprising brightness curve, colour correction, sharpen, crop, and output. This works OK.
I then revised the workflow by adding a geometry/levels and plumb widget before the brightness curve widget. Now I find that the output file has lost its width and height info and the resolution is set to zero. Applying the levels and plumb transformation to the input file, outside of the workflow, works fine.
Am I doing something wrong here, or is this a bug?
Ian
Re: Level and plumb widget causes problem
I don't see a problem here. If the problem persists, please send me your workflow file. (ksinlel@dl-c.com)
Rawcoll
Post by Rawcoll »
I've e-mailed you a workflow Kiril. I created a test workflow using the level widget at the beginning, and it too gives a problematic resultant image.
If I inspect the image with 'window/info', I get dimensions in pixels, but showing *x* cm, 0 dpi (the input image was 360 dpi).
Similarly, if I attempt to use the 'geometry/resize' transformation on the image I get a width and height showing as ' * ', and dpi=0
Ian
Rawcoll
Post by Rawcoll »
Looks like v5.0.1.4 has got this feature working as well. Thanks.
Ian
