Update Available - Version 8.0.543
An update is available to Version 8.0.543 (6-Jan-2026)
Mask Dialog Box: Added a new button to let you change the initial base mask image (or gray level). This is the same as thr base image you can select from the Amount control when you first create a new mask, but now you can change it without starting over.
