Update Available - Version 8.0.542
An update is available to Version 8.0.542 (3-Jan-2026)
Updated to ExifTool version 13.44.
The thumbnails temporarily created in the image browser when the Print or Export commands are executed can no longer be closed from within the image browser.
Changes to masks:
  • Mask settings menu: renamed the Save current mask and Combine saved mask commands to Store mask image and Combine stored mask image. These commands work as before, making a temporary copy of the current mask image that you can use later in the same Mask session. The stored mask image is discarded when you close the Mask dialog box.
  • Relaunched the new Mask Touch tool – see the updated help and Creating and Using Masks.pdf files for details.
A full installation is required due to one new bitmap.
