Update Available - Version 8.0.541
An update is available to Version 8.0.541 (22-Dec-2025)
Added File/Save – Copy Metadata command to let you save the current image but select which file’s metadata is copied to the output file. You could use this, for example to open a PNG file generated by Aiarty Image Enhancer and save it as a TIFF file, while preserving all the metadata from the original raw file.
Modified Distort transformation to use less stack space. This should prevent crashing in some cases. I also increase the size of the stack.
Monitor/Printer Curves: dialog box is now modeless so it can remain open while you use other parts of Picture Window.
Resize: fixed problem with incorrect display of input image memory size.
jfoster
Re: Update Available - Version 8.0.541
Post by jfoster »
The Distort and Resize Memory Size issues look good here now.
