Situation
I often use the speck removal tool to remove dust spots on the sensor. The tool is very efficient in patch match mode.
Finding
When processing a batch of images taken in a mix of portrait and landscape orientations, the speck removal tool warns that the image does not match the original and asks "Clear all specks?"
Problem
When the images in the list have the same aspect ratio but are rotated ( or when a different image size scaling is used while retaining the aspect ratio ) the specks could not be reused.
Suggestion
Offer the possibility to rotate and scale the specks to follow the images in the list. Ask for rotation direction if undetermined.
Feature request : Speck removal for landscape / portrait batch processing orientations
Re: Feature request : Speck removal for landscape / portrait batch processing orientations
This assumes images are always rotated in the same direction. It would probably require user intervention to tell PWP which way to rotate.
Yes this feature would require User Rotation Control & Live Preview:
Explicit Rotation Choice:
Ask the user to specify the rotation direction: Clockwise (+90°) or Counter-Clockwise (-90°).
Live Preview: Implement a feature to preview the effect of the rotation (CW or CCW) before the user commits the rotation.
Additional feature : Orientation-Based Sorting for Batch Processing
Implement a user choice to sort the list of input files by their orientation (e.g., separating portrait from landscape images).
Usefulness
Reduced User Interaction: This feature simplifies processing by allowing all images to be handled in two distinct batches (e.g., all portrait images, followed by all landscape images). This means the user would only need to determine the required rotation once for each orientation group.
Usefulness
It turn out a rotation feature is already implemented (see the two buttons at the far right of the tool bar at the top of the transformation dialog box. This rotates the coordinates of all the specks 90 degrees clockwise or counterclockwise.
