An update is available to Version 8.0.537 (19-Nov-2025)
Fixed problem with code signing certificate.
Added a new tab called All to the Image Info dialog box. This displays the output from ExifTool of all metadata.
To scroll a thumbnail as far to the left as it will go, instead of double clicking its caption bar, there is now a new button at the top of the image browser that shows up only if the image browser has a horizontal scroll bar.
When opening the File Open transformation dialog box and opting to replace files in the list or add files to the list, the starting folder is now the same as the currently open file, if any. Otherwise the last opened file folder is used as before.
Updated to ExifTool 13.41.
File Open dialog box: the context menu you get when you right click on a file in the file list now includes 2 new items: Launch Windows Explorer for file and Copy pathname to clipboard.
Updated to a new code signing certificate – hopefully this will work the same as the old one that recently expired and you will not see any difference or get any messages from the installer.
Update Available - Version 8.0.537
jfoster
Re: Update Available - Version 8.0.537
Seems like there's still a signing certificate issue:
Edition Windows 11 Home
Version 25H2
Installed on 6/24/2025
OS build 26200.7171
Experience Windows Feature Experience Pack 1000.26100.265.0
Processor Intel(R) Core(TM) i7-14700F (2.10 GHz)
Installed RAM 32.0 GB (31.8 GB usable)
System type 64-bit operating system, x64-based processor
Pen and touch No pen or touch input is available for this display
NVIDIA GeForce RTX 4060 Ti 8188MB
Version 25H2
OS build 26200.7171
It appears there is no warning if you uninstall the previous version before installing the latest one. You should only have to do this at most once.
