Update Available - Version 8.0.520
An update is available to Version 8.0.520 (29-Jul-025)
Added Create Color Line from Image command to Edit menu. This creates a color line file from an image by computing the average color of all the pixels in the image for a sequence of brightness values. The average dark colors are at the left end, the average light colors are at the right end and the average midtones are in the middle. The resulting color line can be loaded into transformations such as Tint or Gradient.
Fixed problems with dragging certain resizable dialog boxes between monitors.
madhg
Re: Update Available - Version 8.0.520
Post by madhg »
Thank you for the update. Today I installed it, and found what seems to be a fault.
Using the Level transmn, I could not zoom into the input image by my normal method (Ctrl+mouse wheel). But it works for the output image. When I display only the input image, I can't zoom it.
The same problem occurs with Warp, but not with Curves. Any thoughts?
David Griffel
The way to zoom is Alt + Mouse Wheel, not Ctrl + Mouse Wheel. The Ctrl is ignored in this case, but the mouse wheel works anyway without Alt in situations where there is no overlay on the image you are zoom and the mouse wheel is not being used to control a slider in the transformation dialog box. Similarly dragging to scroll may also require Alt if the transformation dialog box has control of mouse events.
madhg
Post by madhg »
Uggg! should have checked the manual! Thanks.
