UI suggestion : zooming dialog box with curves
Suggestion
When the pointing device (cursor) is hovering over a dialog box with curves or other graphical component, for example the Multi color balance Transformation or the Histogram Tool
  • The scroll wheel zooms in or out the dialog box.
  • Keyboard shortcuts
    • Num Pad + -- Zoom in transformation dialog box
    • Num Pad - -- Zoom out transformation dialog box
    • Num Pad * -- Zoom recall / Zoom to standard size the transformation dialog box
Keyboard Alt and Shift could be used to apply the effect to width or height only
