improvement request : UI behavior in File Open List
Here is a suggestion for improving the UI for File Open.
Current behavior
  • When re-opening the File Open transformation, the red dot indicating the current file is pre-selected ( ready to be moved up or down using arrow keys )
  • When the red dot indicating the current file is clicked, the UP arrow can move up the red dot once. Successive presses of UP arrow have no effect.
  • When the red dot indicating the current file is clicked, the DOWN arrow can move up the red dot once.
  • Successive presses of DOWN arrow : while the file list is displayed, when DOWN arrow key is pressed the effect is to close the File Open transformation, and to navigate down the image tree browser.
Issues
  • Pressing UP and DOWN arrows are unusable for moving the red dot (current file indicator) unless the red dot is clicked beforehand
  • It is undesirable to close the File Open transformation when using the arrow keys.
Suggestions
  • For speed of use, pressing the UP or DOWN arrows should move the red dot without using a mouse click beforehand
  • The File Open transformation should not be exited upon pressing the arrow keys
Re: improvement request : UI behavior in File Open List
