Update Available - Version 8.0.502
An update is available to Version 8.0.502 (8-May-2025)
Mask: the Oval Gradient mask tool now has a Roundness slider like the one in the Oval Gradient transformation. Also when shift is down, the gradient now rotates in increments of 10 degrees.
Mask: Fixed problems with closing the Mask dialog box causing errors in some cases.
Fixed a problem causing an Internal Error when closing a color picker window in certain cases.
