Update Available - Version 8.0.499
An update is available to Version 8.0.499 (4-May-2025)
Favorites: fixed several issues with updating and resizing the Favorites window. Also, the number of buttons per column of favorites can now be set to 5, 10, 15 or 20.
Color Picker: when in Color Wheel mode, you can now optionally display a grid over the color wheel connecting the white point to each of the primary and secondary colors (via its setttings menu). This can be useful when viewing very pale colors to help identify what you are selecting.
Added a dialog box displayed when loading scripts, snippets or workspace scripts to let you terminate the script without having to wait for it to run to completion. Progress bars are now always hidden when loading scripts.
Fixed problem with cancel buttons on progress bars and various other places not always responding reliably on the first click.
Oval Gradient: When shift is down, dragging the radial line to adjust the rotation constrains the angle to be a multiple of 10 degrees. Otherwise, when shift is down, dragging one of the control points to reposition or resize the gradient constrains it to be circular (or square).
