Measure Tool suggestion
Would it be possible to allow the measure line in angle-restricted snap mode to be dragged as a whole. Presently only the endpoints can be moved, and sometimes they don't snap easily where I want them.
Another comment: if I zoom in an image and then activate the Measure Tool, the line is produced in the middle of the image, which may be outside the zoomed portion. Would it be possible for the PWP to react to zooming somehow?
Re: Measure Tool suggestion
If you hold down shift, you can drag both points at the same time.
For the next release, the control points are numbered and you can zoom in on them by pressing the corresponding number key, similar to transformations such as Level or Composite.
