Paint Last Settings
Paint Last Settings
Is there any way to use Paint on an image, with certain parameters, then open a second image and use Paint > Last Settings without the actual paint being copied from the previous image?
I would like to use the same line width/softness/opacity etc (but not the previously drawn lines) on multiple images without having to reset each parameter each time.
Re: Paint Last Settings
If you use the Settings menu to save paint settings, the brush strokes are not saved and you can get the settings back by reloading the settings file.
The only way to do this from the last settings is to undo all the strokes are doing the Ctrl-R.
Thanks Jonathan
