Update Available - Version 8.0.489
An update is available to Version 8.0.489 (19-Mar-2025)
Level: switching between horizontal and vertical now preserves the angle setting.
Batch: aborting a batch process now leaves the current file in the file list set to the last image successfully processed.
Fixed problem causing crash when adjusting the separator between the image browser and the main image area in certain cases.
Holding the Alt key down while switching between an input image and an auxiliary input image for the same transformation now preserves the zoom and scroll information (assuming the two images have exactly the same dimensions in pixels).
