Update Available - Version 8.0.485
An update is available to Version 8.0.485 (18-Feb-2025)
Equalize transformation: dialog box can now be resized vertically as well as horizontally.
Primaries transformation: added a Dynamic Range slider so you can prevent clipping.
Multipass Sharpen: added a Dynamic Range slider so you can prevent clipping. Also optimized resizing the dialog box so the preview does not recompute until you finish resizing.
When reloading scripts saved without image names, you no longer get a warning about missing files when opening the script.
In transformation dialog boxes that have a vertical separator bar (Advanced Sharpen, Color Balance, Denoise, Frame, Gaussian Blur, High Pass, Layout, Linear Blur, Multipass Sharpen, Precise Gaussian Blur, Unsharp Mask, Watercolor), there is now a diamond in the center of the separator bar you can use to drag it, similar to the vertical separator between the image browser and the main image area. This avoids problems adjusting controls near the separator bar.
Fixed problems with dynamic range sliders being truncated vertically in some cases.
