Update Available - Version 8.0.482
An update is available to Version 8.0.482 (11-Feb-2025)
Equalize: made the output curve control (which is read-only) still respond to various display options (grid, histogram expand, histogram smoothing).
The Ctrl-D keyboard shortcut now finalizes the mask if a mask operation is pending, before toggling the display.
Mask “Update transformation with mask” (from the Mask Settings Menu) is now saved and restored as part of the mask settings. Previously it was cleared every time. Now, with this setting enabled, the Apply button is never displayed since masks are automatically finalized with each change. Previously it was still being displayed even though the mask was already finalized. If you want this option to be the default, you can configure the Mask dialog as you want it and use the Mask Settings Menu to save as default mask settings.
Updated to lcms 2.17 color management system.
