Update Available - Version 8.0.477
An update is available to Version 8.0.477 (1-Feb-2025)
Added code to prevent Picture Window main window from starting up minimized.
Levels and Color Tool: fixed several problems causing settings to be incorrectly restored when re-opening the transformation. Added option to alter brightness using a curve instead of Midtone/Contrast/Dynamic Range sliders. Added button to base curve histogram on entire image or just the area covered by the Amount mask.
Levels and Color Transformation: Added option to alter brightness using a curve instead of Midtone/Contrast/Dynamic Range sliders. Added button to base curve histogram on entire image or just the area covered by the Amount mask.
Re: Update Available - Version 8.0.477
Very nice additions, thank you. However, my muscle memory needs re-training now with the rearrangement of slider positions...
Sorry, I needed to rearrange them so switching to the curve did not move everything around.
I completely understand...
I've seen a small issue with the font not being fully displayed in "preferences": "On Workspace Script Load"
