Update Available - Version 8.0.475
An update is available to Version 8.0.475 (14-Jan-2025)
Warp: the state of the tool bar that constrains control point movement horizontally or vertically is now preserved when you close and then re-open the transformation dialog box.
In Transformation submenu, File is now called Batch.
Dehalo: refined the dehalo algorithm.
When saving or exporting raw files, the raw file extension is now stripped off for all common raw file types.
Mask: after finalizing a gradient tool (linear or oval), the freehand lasso tool is now selected. Some issues with Mask Undo still remain and will be fixed in a future release.
Slide Show Viewer: fixed problems with dropping a folder that contains no image files onto the Slide Show Viewer icon.
Geotag Folder: fixed problem with default folder setting not restored correctly.
