PWP7 download page gone?
dimockn
Post by dimockn »
Hi.
When I click Save, on Save Picture Window Pro/64 v7.0 Setup, I get "The requested URL was not found on this server."
Cheers.
N
Re: PWP7 download page gone?
Use one of these links to download PWP 7:
Download Links for Picture Window Pro 7.20
Picture Window Pro 7 has been discontinued for many years now, replaced by version 8. To download the latest version of Picture Window Pro 8, use the following link:
https://www.dl-c.com//Downloads.html
If want to install version 7, you cannot use the download links in the old web site because the installer we used at the time is incompatible with modern web browsers. You can however still download and install it using the following links, depending on which version of Windows you are using:
32-bit Windows: https://dl-c.com/Temp/d ... isable.exe
64-bit Windows: https://dl-c.com/Temp/d ... isable.exe
This version is free and does not require a serial number.
