0xc0150004 error
KipTheKlick
0xc0150004 error
Post by KipTheKlick »
The new version PWP worked fine on my Lenovo windows 11. After several months of use the program would not run (it is still present) and I received this error message. I downloaded again, but received the same message. Ideas for a fix?
Re: 0xc0150004 error
This is not a Picture Window error message. If you google it, you will see it is generally an indication of some corruption of operating system files. There are various suggestions online as to what to do to try and fix this which might help. If not and if it was my computer I would seriously consider backing everything up, formatting the hard drive, and re-installing Windows and all the applications. It is also possible there is a hardware problem, so try running some diagnostics first.
