Update Available - Version 8.0.470
An update is available to Version 8.0.470 (16-Dec-2024)
Mask: fixed issues with certain settings (e.g. Mask Paint tool) not being restored correctly after an undo.
Print command and transformation: fixed problems with auto orientation in some cases when the cropping rectangle did not cover the entire image. Added two more scale options: scale to custom width and scale to custom height. These options fix the width or height and adjust the other dimension according to the proportions of the cropping rectangle. Note that width and height refer to the (possibly) rotated image on the page.
Changed the icon in the image browser for copying selected transformations to make it different from the copy to clipboard icon at the top of the screen. A full install is required to get the new bitmap.
The yellow check marks indicating transformations are selected are now cleared when you select anything (either command or transformation) from the main menu (or click a button that indirectly activates an item in the main menu). Hopefully this will reduce the annoyance of forgetting transformations are selected when trying to make a new selection.
Favorites: added a Settings Menu to let you keep the favorites window open after selecting a transformation. Also, the position of the window is now preserved across sessions.
